Truck wont start
Old Jan 21, 2021 | 06:43 PM
George Weston's Avatar
George Weston
Default Truck wont start
2006 1500 megacab 5.7l hemi. Pulled into a gas station shut off the engine. After getting gas truck would not start again. Replaced cam and crank sensors, tipm, fuel pump works and the is fuel in the rail so I know it is getting gas. If I turn the ignition on and stomp the gas pedal it seems like it is going to start but then don't. It seems like it is not getting spark hence the new sensors. Dodge mechanic said it sounds like the stater relay built into the timp hence replacing the tipm box. So... after just about 1000.00 but later still nothing. Please someone give me an idea of where to go from here...short of lighting a match to it.
Old Jan 22, 2021 | 08:50 AM
Will it fire off on starter fluid?
Old Jan 22, 2021 | 09:47 AM
George Weston
No it won't just checked it now. I'm put the obd2 on it and got code p0113. Will this iat sensor keep the engine from starting?
Old Jan 22, 2021 | 11:37 AM
Intake Air Temp sensor. It's in the passenger side of the intake manifold, just forward of the throttle body. Never heard of one causing a no-start though...... Unplug, and see what happens.
Old Jan 22, 2021 | 05:03 PM
George Weston
So far today I have tested all 8 coils and they are good. Replaced all 16 plugs(old ones were wore ot to double the gap size) and replaced the iat sensor. Removed the tipm to do a hard reset then gave the truck 2 minutes to relearn then tried starting no luck still just cranks away. Dash dtc popped p2110 throttle actuator control system. And I have no idea how to test it. Can't find a tps I see a acc on the gas pedal. I really don't know where to go from here
Old Jan 22, 2021 | 09:47 PM
You need a factory service manual. There are troubleshooting steps in there. You can probably download one from EBay, or Amazon, for 30 bucks or less.
