03 5.9l cummins trany cooler
Old Jan 21, 2021 | 10:16 PM
austinsn's Avatar
austinsn
Default 03 5.9l cummins trany cooler
Transmission is a 48re. So the 2 rubber lines that have quick connect ends was both leaking so I replaced both but they are both still poring out on the end of the cooler. The only thing I can think of is the tube where they slide on is too warn. Any ideas to fix besides buying a new 200 dollar cooler thanks.
thats before I cleaned and installed new
Old Jan 22, 2021 | 08:49 AM
Did you lube the new connectors before installing?
Old Jan 22, 2021 | 09:03 AM
austinsn's Avatar
austinsn
Yes I did
Old Jan 22, 2021 | 09:30 AM
If they are still leaking, I would be tempted to replace them with some hose, and a couple clamps......
Old Jan 22, 2021 | 09:47 AM
austinsn's Avatar
austinsn
I thought about that but im not sure how much pressure would be going through them.
Old Jan 22, 2021 | 11:36 AM
It's just a cooler, so, not a lot of pressure. Consider, the factory used hose clamps back in the day.
