No low beams and random right high
Old Feb 3, 2021 | 08:52 PM
Christopher Caspersen's Avatar
Default No low beams and random right high
So I have a 2006 1500 3.7 v6 and my low beams have stopped functioning. I installed HID headlights to replace the dim factory bulbs a few years ago and everything was fine but after a while the low beams would sometimes not come on and eventually completely failed. Thinking it was just the bulbs and tired of headlight warmups I replaced with LED recently... Still no low beams even with resistors attached. I disconnected the TIPM and found no corrosion or damage, cleaned and greased the connections and hooked it back up... no change. I replaced both the headlight switch and the dimmer switch.. no change. Power is going to both the high beams and low beams.. I’m at a complete loss.
I’ve cleared the computer of any possible codes and done a hard reset of the TIPM.
Anyone been having this issue or know what the cause could be???
