Adding a Winters Shifter to a 545RFE, anyone done it?
Old Feb 20, 2021 | 03:02 PM
Yell-hoe's Avatar
Yell-hoe
Default Adding a Winters Shifter to a 545RFE, anyone done it?
Running into issues with the cable. Part is 52109624AD. Was trying to find a way to remove the ends and swap to the new Winters Shifter cable as well as re-use the bracket that retains the cable to the side of the tranny itself.
Cheers
Old Feb 21, 2021 | 04:14 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
What possible issues could you be running into with it unless you burned it on exhaust somehow?
Old Feb 22, 2021 | 09:09 AM
Yell-hoe's Avatar
Yell-hoe
For one Winters does not make a shifter kit for the 545RFE. I am using a shifter kit for a TFT727 as it has the closest gate pattern.
I need a way to retain the housing casing fixed to allow the rod to slide as it shifts.
My original question was to know if there is a way to remove the ends of the shifter cable and brackets.
Thanks
