steering pulse/moan
forgive me if in wrong area I posted in truck area, no readers. I have a Personal 2010 ram 1500 4x4 quad cab slt 85k miles It has developed a pulse & moan only @ 35 mph or faster, I can feel it in steering wheel ONLY WHEN TURNING RIGHT & it also does it when I go over a hump or rise in the road going straight @35 mph or higher . fluid is good No symptom when turning left nothing visual i can see. I have put in & out of 4wd, I have turned the traction control off & on still same. anybody have this issue? driving me crazy thank you in advance Bob
Maybe it's moaning because it's tired of going right.
got into it more last night the RIGHT OUTER TIE ROD is bad moved just enough to touch backing plate causing the tone/vibration Its a tight fit there & I didn't see it at 1st w/ tires on . installing a new one now. AS ALWAYS THANKS FOR LOOKING EVERYBODY BUT why its failing at this low mileage is beyond me.
YEP, I found problem today , RF outer tie rod was bad, it would lean out & contact the rear rotor thin metal backing plate & rub it transmitting sound & vibration. the clearance is very tight. . I REALLY miss My 05 1500 crew 4x4 4.7 , should of never traded it . Never had anything except a water pump & EGR valve & a ac mode unit/motor in dash owned from new to 225k miles, other than service, spark plugs, tires & oil not a thing this 2010 I got w/ 46k miles on it on 2017 . NEW REAR./ EATS BRAKES/MANIFOLD STUDS/ NOW STEERING. @86K MILES may trade again.
