Infinity system.
Old Mar 8, 2021 | 06:55 PM
Corey Slone's Avatar
Corey Slone
Default Infinity system.
So I'm in the middle of trying to bypass the stock infinity amp and I may have jumped the gun on cutting all the wires on both plugs at the amp. I've had an aftermarket stereo and aftermarket door speakers and a sub up till now playing. Now I am having trouble even getting the ignition to turn on and I've checked my fuses which I did blow the cluster radio fuse and I've changed it but still no response. I'm hoping I didn't mess up too bad. Any help would be more than appreciated. It's the 3rd day ole blue has sat and not even turned on. Thanks.
Oh btw Its a 2004 ram 1500 5 7 with the premium infinity sound system.
Old Mar 9, 2021 | 11:09 AM
Ram316's Avatar
Ram316
I started to run into this. I through in the towel and took it to a local audoio shop. I got too nervous of screwing something up. They installed all the bypass stuff and bass blockers. Excited I have a working radio. :-P. Now I need to upgrade my speakers. Hopefully you can figure out what is going on. I would for sure go through fuses. Reset the battery/PCM and go from there.
Old Mar 13, 2021 | 02:20 PM
Corey Slone
So i finally figured it out. I had no idea about the theft mode in this truck but it basically was in theft the entire time and I had no clue. I took out battery and clamped my cables together and it reset after about 30 minutes but am still trying to figure out the bypass stuff. Still trying to find wiring and online stuff. The struggle is real
