3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Test coolant for combustion gases, you can get the kit for that at the parts store.
Also rent a cooling system tester, which pressurizes the system without having to deal with the danger of heat or moving parts. Pump to max psi stamped on your radiator cap, then wait to see if it drips.
Thank you. I will give that a try as soon as I can.
