Truck won’t go past 3k rpm
Old Mar 18, 2021 | 07:10 AM
Miles Ferree's Avatar
Miles Ferree
Default Truck won’t go past 3k rpm
I recently bought a 2003 1500 with a 4.7 and it doesn’t rev past 3k at all no matter what I’m doing. It’s not a park or neutral limiter, the cel is on and the codes it has is p0700,p0720,p0420,p0440
Old Mar 18, 2021 | 07:55 AM
It's in limp mode most likely due to the CEL codes. Fix the known problems. Didn't you test drive it before you bought it?
Old Mar 18, 2021 | 10:04 AM
jrsick's Avatar
jrsick
the 700 and 720 codes are often due to a faulty differential speed sensor. There are videos for checking, cleaning, or replacing the sensor. I rec you replace the sensor then reset all codes.
