Newbie
Old Mar 17, 2021 | 02:03 AM
Jim Stephens's Avatar
Jim Stephens
Default Newbie
I,'ve got an 02(new body)ram1500 3.7 5speed manual. Also have 06 Chrysler 300 srt8. My question is for the Dodge. Can I bolt my rear discs on about 98 ram1500 drum rear end and will that rear bolt up to my truck. Thanks
Old Mar 17, 2021 | 06:57 AM
Didn't Dodge go to different axles in 02?? Aren't they AAM, instead of corporate? Or did that happen later?
Old Mar 18, 2021 | 11:32 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
No, 2002-2008 1500 rear axles are the good old 9¼. So you're trying to put your brakes on a 1998 rear to put under your 2002?
Old Mar 18, 2021 | 04:03 PM
69_XS29L's Avatar
69_XS29L
3rd Gen rear discs will bolt to a Gen2 drum differential if you move the mounting plates. The '98 will fit your '02, change the pinion flange, check your ABS sensor/wiring.
