Error Code P2096
Old Dec 26, 2005 | 01:10 PM
Red Ram Hemi 2005's Avatar
Red Ram Hemi 2005
Default Error Code P2096
P2096 or P2098 Post Catalyst Fuel Trim System Low Limit. Does any one know what this means?
Old Dec 27, 2005 | 06:08 AM
Red Ram Hemi 2005
Default RE: Error Code P2096
Any clues?
Old Dec 28, 2005 | 01:21 AM
tenntech's Avatar
tenntech
These codes are not a very common code and will probably take a good tech to diagnose. A few guesses would be contaminated fuel, vaccum leak, O2 sensor, exhuast leak, or engine mechanical problems. Also you should make sure you have not made any mods. or added anything to your fuel that could effect your fuel/air mixture.
Old Dec 28, 2005 | 07:03 AM
Red Ram Hemi 2005
Truck is stock nothing has been touched, no addded fuel octane boosters or anything. Went on a long trip and noticed that I need to change the airfilter when I got back. I changed it and thought that might be the reason for the dummy light but hasent turned off yet.
Old Dec 29, 2005 | 11:22 AM
Red Ram Hemi 2005
I was wrong P2096 is Post Catalyst Fuel Trim System To Lean Bank 1. I really havent found anything on this.
Old Feb 24, 2010 | 04:42 PM
alexandre5.7's Avatar
alexandre5.7
i have the same code on mine and the dealer says that is probably the o2 sensor after the cath that is bad,so i order one today and i'll see what happen
Old Apr 3, 2010 | 11:49 PM
redlinegw's Avatar
redlinegw
My 08 Dakota 4.7 threw the same code, the dealer replaced the oxygen sensor and 2 days later the light came back on and the trucks shudders at part throttle. This drive by wire stuff is crap! I hope they can fix it, I just bought the truck like 3 weeks ago from Cerritos Dodge and now all of this! NOT HAPPY!
