Misfire on 2 and 6 Stutter at 80/km
Old Mar 25, 2021 | 01:12 PM
farmzgirl's Avatar
farmzgirl
Default Misfire on 2 and 6 Stutter at 80/km
2002 Dodge Ram 1500 ..4.7 has 224,000km. Engine light on. scanned , misfire on multiple. Ignition B primary. and large evap .leak.
replaced plugs
coil packs are good
replaced cam and crank sensor
fixed evap leak on canister
still have misfire on 6 and 2 and when vehicle reaches 80km to 100 km there is a stuttering when gas is applied ..let of gas it stops over 100km no stutter
spark advance is all over at an idle but at 1500rpm it holds at 31.5 seems high to me.. any thoughts are greatly appreciated
Old Mar 25, 2021 | 01:47 PM
Swap the coil on 2 and 6 with some other coils anyway. (and not just with each other....) see if the misfires move with the coils.
Old Mar 25, 2021 | 02:06 PM
farmzgirl's Avatar
farmzgirl
We had done that previously.. just did compression test on 6 needle didn't even move
Old Mar 25, 2021 | 03:37 PM
That's not a good sign...... Pull the valve covers, see if it didn't spit out a rocker arm.
Old Mar 26, 2021 | 01:05 AM
Prismatic's Avatar
Prismatic
My moneys on rocker arm as well. Horrible design IMO. I've had to replace an entire set of (similar ones) on a friends pentastar.
Old Mar 27, 2021 | 09:57 AM
dhawke's Avatar
dhawke
replaced plugs
coil packs are good
hey you might have a bad cam and lifters or a broken valve spring or spring's i am also having a p0303 code on #3 cylinder I checked the coils even replaced them seems to be a common problem with the mds system
