Engine shaking when A/C is on
Old May 8, 2021 | 01:18 AM
Matthew White's Avatar
Matthew White
Default Engine shaking when A/C is on
04 Ram 1500 5.7L runs nice until I turn my A/C up then it starts to shake. Gets worse the higher I turn it up. Any ideas. I just cleaned my throttle body so far. Mybe the compressor is sticking or going out?
Old May 8, 2021 | 08:07 AM
jrsick's Avatar
jrsick
With the truck off, can you turn the a/c clutch (the center of the compressor which the compressor pulley spins around)?
If not, then your clutch has frozen.
If you can turn the clutch, try starting the truck with the a/c off, then have someone turn the a/c on high/cold while you watch the compressor.
If you are able to replicate the shaking while you are watching, take a look at the engine mounts.
Shaking the engine sounds odd to me. With a/c compressor problem, I would expect belt squeal but not a shaking engine.
Old May 8, 2021 | 08:14 AM
Matthew White
Thanks I will check that when I get home. It does blow out nice cold air so not sure if it’s frozen. and can’t feel it shake when it’s on low. But once I turn it up you can feel it start shaking.
Old May 8, 2021 | 12:26 PM
66three83's Avatar
66three83
You probably have something stuck in your blower motor. The higher you turn it up, the more vibration you will get.
Old May 8, 2021 | 02:07 PM
Matthew White
How would I clean it out? Or test if it’s clogged up?
Old May 8, 2021 | 02:25 PM
66three83's Avatar
66three83
Just remove the three screws holding it in, it comes right out. before you do, just hold your hand on the motor as you go through different speeds and see if the vibration is coming from there. Even if there is a leaf stuck in there it will make a tremendous shake and racket.
Old May 8, 2021 | 02:26 PM
66three83's Avatar
66three83
or just sit in the driver seat turn the ignition on without starting, and crank the fan up see if that’s what you’re feeling.
