3rd Gen 5.7 Won’t Move In Gear
Old Jun 9, 2021 | 06:21 PM
greg.hayes2003's Avatar
greg.hayes2003
Default 3rd Gen 5.7 Won’t Move In Gear
I have a 2005, 5.7 hemi that will not go into gear. Park does work, and while in neutral the RPMs drop for a brief second before leveling out, changed the transmission filter and fluid, nothing has changed. Can anybody help?
Old Jun 9, 2021 | 06:29 PM
jrsick's Avatar
jrsick
Did anything happen right before problem started? Like transmission fluid change?
What codes are you getting?
Do you have access to code scanner? Many auto parts stores will read codes for you.
Old Jun 9, 2021 | 06:34 PM
greg.hayes2003
We got a P1715 code, and the front driveshaft had a crack that has a minor leak of trans fluid, I’d also like to add that we have put in 10 qts so far and it’s still not full, I don’t see how it could’ve drained the torque converter as well though
Old Jun 9, 2021 | 10:17 PM
hwykat's Avatar
hwykat
4x2 -11.0 Quarts
4x4 -13 Quarts
did mine bout 5 months ago mine held 13 quarts
