Random Flashing ABS and Brake Lights.
RE: Random Flashing ABS and Brake Lights.
ORIGINAL: ALLSTAR RAM
Check for water in your abs controler connector, Have seen water build up in connector comes from ground directly behind battery and wicks down to cab moduel.
^^ Alright thanks for the input, I'll definitly check this out tomorrow and see whats going on with it, I just been pretty lazy about it lately and hoping someone had some input on here before I waste time going to the dealer to give me some run around story and send me home.
ORIGINAL: bmxox
My truck has been having a popping noise coming from either the front suspension and the steering likes to shudder from time to time turning left. They have replaced the PS pump and lubed the sway bar. Only hear it every now and then, but aggravating none the less.
I just don't have the time to drop the truck off, find a ride to school for a day or so and have them tell me nothing is wrong.
HOLY CRAP! Same EXACT thing with the ABS, Airbag and Brake lights has been happening to my 05 Ram 1500 SLT. No dropping speedo needle. 2 different dealers cannot duplicate the problem or find a code. (sure they are not looking hard) Did you ever get this figured out? Very curious!
yes, my '06 had solid ABS and brake warning lights with speedo frequently dropping out and associated "ding". Dealership replaced ABS computer. No more problem. Now, if only they could figure out how to solve the shift problem from 1st to 2nd and 2nd to 3rd...
