Blower motor problems
Old Jun 12, 2021 | 06:05 PM
DystopianVic's Avatar
DystopianVic
Question Blower motor problems
I recently ripped out an old remote start system that a previous owner (the original owner, I am the 3rd owner) had installed. The wiring they made was a rats nest so I removed it because it wasn't connected anymore and it was a fire hazard. But when I took it out the a/c and heater fan stopped working all together. I have had problems with that before, but I used to just tug on the bundle of wires and something would click and then the fan would run, I think the click was one of the relays the guy had in the bundle of wires. I tried testing the blue wire from pin 8 on the ignition switch, which is the power cable for the fan, and it still sends a signal over to the blower, so that isn't the problem. Is there anything else under the steering wheel that connects to the blower that I am missing? I've tried to remove as much of the plastic trim as possible to see the wires and where they go, but I can't see anything else that goes to the blower from under the dash. Is it as simple as replacing the ignition switch? The guy I bought the truck from said he had already replaced the switch, but with everything attached to the wires the that was connected to the switch, I could see it being a problem. I tried to not remove any wires that looked like they were a factory job. I also tried testing the fan switch itself and all of the wires that go to the motor work perfectly and the switch still works, so I am not sure what I am missing.
Old Jun 12, 2021 | 06:38 PM
Probably the ground for the blower switch. Blower should be powered with ignition on, blower switch just provides the ground path. Need wiring diagrams for your truck? Check here..
Old Jun 12, 2021 | 09:06 PM
DystopianVic
I don't know what the problem was but once I put everything back together the fan was working just fine. Thanks for the help though.
