3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Most common causes of black smoke are faulty injectors, a faulty injector pump, a bad air filter (causing not enough oxygen to be supplied), a bad EGR valve (causing the valves to clog) or even a bad turbocharger.
