A/C Blower Motor Issues
Old Aug 22, 2021 | 02:54 AM
BrandonN-Dreamer Tyrone's Avatar
Default A/C Blower Motor Issues
So recently my a/c stopped blowing. I checked the compressor and the condenser fan and both are working properly. I noticed that the blower motor was not working so before I considered pulling it to replace it I checked the fuses and relays, which were all still good. Then I pulled the quick connect wiring from the back of the blower switch and checked to make sure it was getting power and it doesn’t have a hot regardless if the truck is off or on. Any ideas on where to start looking to where that hot should be supplied from?
Old Aug 22, 2021 | 08:36 AM
Should be able to find wiring diagrams for your truck here.
Old Aug 22, 2021 | 09:17 AM
jrsick's Avatar
jrsick
You could have a failed a/c control panel, the switch itself. There are some videos for checking potentiometers.
