What kind of fuel do i use for the hemi 5.7?
Old Dec 29, 2005 | 02:58 PM
twiztidz's Avatar
twiztidz
Default What kind of fuel do i use for the hemi 5.7?
I was looking in the manual and it says 89 fuel is to be used with the hemi. I have been using the 87 is that hurting performance and what not. I know this is a newbie question.
Old Dec 29, 2005 | 03:24 PM
HemiBuell's Avatar
HemiBuell
Default RE: What kind of fuel do i use for the hemi 5.7?
The manual recommends 89 but says 87 is acceptable. If it isn't pinging use the 87. I have only put the 87 in it, even in 100 degree weather without any detonation.
Old Dec 29, 2005 | 03:40 PM
Verano's Avatar
Verano
I use 87 in my hemi and I dont have any problems either.
Old Dec 29, 2005 | 03:42 PM
wreckless123's Avatar
wreckless123
If you are not familiar with the "pinging" noise and are still concerned, any good shop can scan your PCM (computer) for KR. KR is "Knock Retard" or how may degrees of retard your motor is needing to accommodate the lower octane gas.. The computer is able to adjust some for the lower octane gas..
Old Dec 29, 2005 | 05:16 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: twiztidz
I run 89, changing to 91/93 in the summer as I will have some programming done that will require it.
Look at it this way. DC recommends 89. 89 will cost you an additional .10 on average, or 2.60 per tank. Worst case I can imagine is filling up once a week, which I think is extreme, when I did drive mine daily I could get 10 days out of it. That would be just over $130 a year (weekly fill) you would be saving by not running the recommended. Is it worth it? I would say for $2.60 a tank get the recommended. Run 89.
Old Dec 29, 2005 | 07:02 PM
HemiBuell's Avatar
HemiBuell
ORIGINAL: 94rt10ohio
I am pretty sure this is false. The higher octane number just prevents detonation. Gas is supposed to burn in your engine not explode. I was told by a very succesful engine bulder that a higher compression ratio or a hotter air/fuel mixture are the only reasons to run a higher octane.
Who told you a new program requires a higher octane?
Does the programming advance the timing so much that a higher octane is required?
Save your money and run 87 there is absolutely no advantage to a higher octane, especially a 93.
I drove up mount washington, towed a boat way too big for my truck in 100 degree weather and just generally pound on my truck everyday. Never had a ping on 87.
Old Dec 29, 2005 | 07:45 PM
wreckless123
ORIGINAL: HemiBuell
Yes programming DOES require higher octane. When you buy a programmer you have a few different programs that are created with different octane ratings in mind..
Old Dec 29, 2005 | 08:26 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: wreckless123
ORIGINAL: HemiBuell
Thank You! This is correct, programming does require different octane, depending on what is changed.
Now, another thing to consider. Many new cars will say 87 is OK but 89 is best for optimal performance. The computer can actually adjust your timing for lower grades of gas, resulting in less power.
Old Dec 29, 2005 | 10:53 PM
spinfreak's Avatar
spinfreak
I don't know about ya'll, but my '03 gets a hell of a lot better mileage running 93 octane than it does running 87 octane. For the first 6 months that I owned the truck (got it used in April '05) I was using 87. I was averaging about 9-10mpg city, and maybe 12mpg highway. I then tried 93 octane. My mpg went up to approx 12-13 city, and 14-15 hwy.
I didn't have any problems running the lower octane besides crappy mileage. I didn't do anything other than using 93 octane to get the better mileage. No different gas stations (whatever is nearby when I need gas), or anything. It works for me, so I'll stick to it.
Old Dec 29, 2005 | 11:21 PM
IshouldaGOTtheHEMI's Avatar
IshouldaGOTtheHEMI
i'm not sure but dosen't the manual say that you need 91/93? i'm not posetive and don't have a hemi but i think i saw it.
