04 Ram 1500 No Crank No Start
Old Oct 19, 2021 | 09:59 AM
Orhnry's Avatar
Orhnry
Default 04 Ram 1500 No Crank No Start
Hey guys. I've had some issues with intermittent no crank no start on my 04 Ram 1500. It all started back in June one day I went to turn the truck on and the starter made a single clunk sound. I ended up replacing the starter and that didn't fix it. Somehow that day it decided to start for no real reason. After that it ran fine but sounded like it was weak to start sometimes. A few weeks ago same thing happened and it wouldn't start again. I didn't really have time to check it so I left it sit until yesterday I needed to pick something up and prayed it would start and it did. The only weird thing I notice is that the guage cluster shows all gears lit up. When I shift through them a few times it goes back to normal. Any tips on what this could be?
Edit: Forgot to mention during the winter sometimes my ETC light will appear and my revs will bounce unless I restart the truck which makes it go away. Not sure if relevant or not.
Old Oct 19, 2021 | 10:32 AM
Moving this to Third Gen Ram section for ya.
Old Oct 19, 2021 | 11:51 AM
jrsick's Avatar
jrsick
I rec you first tackle the start problem.
What is your battery voltage static? Should be at least 12.4v, 12.7 is better.
When you test the engine as a ground are you still getting same reading?
While testing battery voltage, have someone start the truck. How much did the voltage drop? It should drop, but not below 10v.
Ideally you would get a reading when the starter is not working correctly. This will help you determine if problem is starter, battery, or connections.
Let us know testing results and we'll go from there.
Regarding the lit up gears and bouncing revs, a bad ground connection will cause all kinds of crazy problems.
