Interior lights dim until visor or glove box open
Old Oct 29, 2021 | 09:10 AM
Skylersell's Avatar
Skylersell
Default Interior lights dim until visor or glove box open
The Interior lights have been modified by the previous owner to leds and are dim when ever you turn them on. If you open the visor or glove box they turn all the way on what could cause this.
Old Feb 16, 2023 | 08:24 PM
Catalystgd's Avatar
Catalystgd
Did you ever figure this out?? I have an 04 ram 3500 with the exact same issue. Led bulbs and they only come on if you open the glovebox or one of the visors.
Mine also screams about a lamp out whenever the headlights are on and you use a turn signal. no bulb is actually out.
Old Feb 16, 2023 | 08:42 PM
Skylersell's Avatar
Skylersell
I haven't been bothered to fix the issue I wonder if it has something to do with the resistance of the leds being Lower than the stock bulbs.
Old Feb 16, 2023 | 08:44 PM
Catalystgd's Avatar
Catalystgd
Could be. I might go and get factory bulbs and see if that solves my problems. Chrysler electrical systems are weird lol
Old Feb 17, 2023 | 08:05 AM
Alex Medeiros's Avatar
Alex Medeiros
LED bulbs in a system set up for Halogen bulbs can cause random things like that to happen. It probably would be best to try factory halogen bulbs and see what gives.
Old Feb 17, 2023 | 08:07 AM
Catalystgd's Avatar
Catalystgd
I just purchased halogen bulbs and will install them today or tomorrow and let everyone know
Old Feb 19, 2023 | 07:40 AM
racerxv6's Avatar
racerxv6
Without a resistor to regulate the power you will experience that, and most likely on any car that isn't wired for led.....
Old Feb 19, 2023 | 01:54 PM
Catalystgd's Avatar
Catalystgd
Default Solved!!
Hello all! I just purchased an 04 ram 3500 dually with this problem. Today I replaced the aftermarket LED bulbs with the factory halogen bulbs and that solved all the issues. Hope this helps somebody!
