Bought a Used transmission, did I get a 45ref or a 545rfe
Old Nov 20, 2021 | 01:37 PM
Junkyard Junkie's Avatar
Junkyard Junkie
Default Bought a Used transmission, did I get a 45ref or a 545rfe
Hi,
I just bought a used 5.7L Hemi and what I thought was a 545rfe from a 2008 Ram 1500 4x4. Both are going into a 2008 Jeep Wrangler Rubicon.
When I took the converter off the plate behind it says 45rfe. I have no proof that the trany and engine are from the same vehicle. The seller has already lied to me about the millage and I'm going through my credit card company to deal with that.
The info tag on the side of the trany is worn off. Casting number is 479960. And a 660 N.
My understanding is that the 45rfe was no longer made after early 2000's. I know both are identical, but I figure by 2008 they would not still be using the 45rfe cover.
Thanks.
Old Nov 20, 2021 | 04:42 PM
Junkyard Junkie
I just took a closer look at the tag provided by the salvage yard. It's mostly rubbed off but you can just make out the 2007 and the partial VIN does not match the engine VIN.
So at least it could be a 545rfe, with a 45rfe cover?
Thanks.
Old Nov 21, 2021 | 11:32 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Same transmission. It's the programming that determines whether it acts like a 45 or 545.
Old Nov 22, 2021 | 03:24 AM
Prismatic's Avatar
Prismatic
45RFE, 545RFE, and 65RFE, same transmissions. 45 and 545 are interchangeable, 65RFE has valve body rework but otherwise the same.
