3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I just had my mechanic install a brand new magnaflow catalytic converter on my 04 1500 hemi. When I got the truck home I checked the new cat with my infrared thermometer. From what I understand the temp should be roughly 20 degrees hotter coming out of the cat, but mine is a whopping 250 degrees hotter going in.
So my question is, does the cat need a break in or something? Or is something wrong?
Something is seriously awry there then..... that's hot enough for the cat to be doing its thing. Sounds like it is either empty, or plugged....
I just thought on something. You said empty and I read that a new cat needs a break in. From what I read the inner part expands once broken in. Is it possible that it hasnt expanded yet and the exhaust is just going around it rather than through it?
