Sound System Upgrade/Modification
Hi folks,
I’m looking to improve the sound system in my 04. It’s a Laramie, but has the standard 4-speaker system and doesn’t have the steering wheel volume controls. I intend to install the steering wheel volume controls as well as the three dash speakers. Questions: Does the standard system have an external amplifier like the infinity system does? Do I need one for adding the three speakers in the dash? Can the dash speakers be wired to the speakers in the front driver and passenger door speakers? As for the steering wheel controls, the wiring harness for the switches is already in the wheel, but when I hooked up switches, it doesn’t do anything… not sure why exactly. Any good advice on installing those would be helpful. I’ve went through a post showing a detailed install of these controls from 2005, but I’m confused about why there is so much wiring involved. It seems with some things, you’re able to simply plug in a switch and—boom—it works, but not with these. If anyone can explain why the C2 Pin 12 from behind the gauge cluster is involved in hooking them up, that would also be appreciated. I’ve called several shops that do these sorts of installs and they’ve said they won’t bother because it’s an older vehicle and I’m not bothering the dealer seeing how expensive that would be, so just any good information would be great!
Thanks!
Thanks!
A good place to start would be metraonline. Metra makes dash kits and stereo adapters for every vehicle. You'll want to add the SWC (steering wheel control) dongle.
You didn't ask, but consider skipping the steering wheel control altogether. Get a multimedia head unit with touch screen that you control with your phone. This will give you versatility to add sub or backup camera later. Just a rec.
You can tap into the wires for your front door speakers to add dash speakers. You will not get much power and will likely be disappointed. I think your head unit puts out 14 watts/channel. You asked about wiring to speakers in the front, and, front door speaker; you don't have both with the four speaker system. If you do have both them you have the Infinity system and that is much different setup. You may want to call Crutchfield to get more info on your system.
Metra has a helpline and you can ask them your pin question.
That's what I was thinking of. Metra or Crutchfield can make sure you get the harness that suits your needs.
Crutchfield will usually give a significant discount for the wiring harness if you buy the head unit or speakers from them. Crutchfield customer support and returns are excellent.
Here is my write-up on steering wheel controls.
https://dodgeforum.com/forum/3rd-gen...installed.html
I guess I should add some more info. I did check out the link to the mod, which will likely help me so thanks! But I don’t intend to switch the radio out for a newer one. I might, but my intent was to keep the original radio (sort of). Technically, the original radio is gone. I replaced it with the exact same thing—except modified with the aux port off JEGS. I know when people change radios, often they lose the SWC, but it’s the same radio with all the same pins plugging up to my harness. Just throwing that out there in case it matters...
Look into the adapter I used, maybe it can convert the signal into a stock Dodge signal.
