03 ram single cab decker panel/cab corner replacement
hello everyone.now that I have gotten all the mechanical kinks worked out I have a few questions with my rust issues. first and foremost the rocker panels are shot,inners and outers there is nothing left. as well as both cab corners. so has anyone ever replaced both at the same time and if so what replacement parts did you go with? also how was the fitment,as I'm torn between replacement panels or buying a new cab. thank you in advance
Six of one, half dozen of the other.
Repair panels would likely be easiest, depending on how bad the rust is. LMC truck, along with a few others, should have repair panels available. See what they got, go from there.
