Are these shared between Dakota, Rams and Durangos?
Old Feb 10, 2022 | 09:43 PM
Dodgevity's Avatar
Dodgevity
Default Are these shared between Dakota, Rams and Durangos?
I broke my power window switch bezel when I was replacing the driver's door power window regulator in my 03 Dakota quad cab a few weeks back. I hit the junkyards last weekend and searched strictly 01 - 04 Dakota quad cab and 01-03 durangos. Now I see this on ebay and it looks like pretty much any of the 4 door Ram pick-ups also carry this switch. I could kick myself for not having looked at them in the scrap yard. All I need is the plastic bezel the switch is mounted in. My switch is good. Are all the quad cab Rams listed really using this same switch too?
https://www.ebay.com/itm/31384164000....c101113.m2108
For sale is a door power control switch removed from a 2004 DAKOTA with 178645 Miles (VIN# 1D7HL48K64S649227 / STK# 0923M). Specific info about the fitment and options are found below.
Interchanges With:
DAKOTA 2001 - 2004 Driver's; (master assembly), Quad Cab
DODGE 1500 PICKUP 2005 - 2008 Driver's; (window, master), Quad Cab
DODGE 1500 PICKUP 2004 - 2004 Driver's; (window, master), Quad Cab, exc. SRT10
DODGE 1500 PICKUP 2002 - 2003 Driver's; (window, master), Quad Cab
DODGE 1500 PICKUP 2006 - 2008 Driver's; (window, master), Mega Cab
DODGE 2500 PICKUP 2006 - 2009 Driver's; (window, master assembly), Mega Cab
DODGE 2500 PICKUP 2003 - 2003 Driver's; (window, master assembly), Quad Cab
DODGE 2500 PICKUP 2004 - 2004 Driver's; (window, master assembly), Quad Cab, exc. SRT10
DODGE 2500 PICKUP 2005 - 2009 Driver's; (window, master assembly), Quad Cab
DODGE 3500 PICKUP 2006 - 2009 Driver's; (window, master assembly), Mega Cab
DODGE 3500 PICKUP 2005 - 2009 Driver's; (window, master assembly), Quad Cab
DODGE 3500 PICKUP 2010 - 2010 Driver's; (lock and window), Chassis Cab, Quad Cab
DODGE 3500 PICKUP 2003 - 2003 Driver's; (window, master assembly), Quad Cab
DODGE 3500 PICKUP 2004 - 2004 Driver's; (window, master assembly), Quad Cab, exc. SRT10
DURANGO 2001 - 2003 Driver's; (lock with mirror and window)
Old Feb 11, 2022 | 08:55 AM
jrsick's Avatar
jrsick
I don't think that list is correct. The switch bezel pictured will not fit in a 3rd Gen 1500.
Old Feb 11, 2022 | 09:24 AM
aleekat's Avatar
aleekat
Go up RockAuto.com. Search for your part. In the results click on the part number and it shows what it crosses over to.
Old Feb 11, 2022 | 10:01 AM
jrsick's Avatar
jrsick
There is a difference between the switch and the bezel. The switch is probably the same for all of those models, but the bezel is different. The ebay ad is getting the two confused.
Old Feb 11, 2022 | 06:50 PM
Dodgevity's Avatar
Dodgevity
You're all correct. I started searching on Ram switches last night and the bezel was indeed different. Thx
Old Feb 12, 2022 | 03:31 PM
Dodgevity's Avatar
Dodgevity
Was able to pick up a few bezels at the junkyard today, so now I even have a spare.
Thx again.
