P0300 Pending
Old Feb 13, 2022 | 09:52 PM
RAM035.7's Avatar
RAM035.7
Arrow P0300 Pending
Old Post delete
Old Feb 14, 2022 | 12:40 AM
master tech's Avatar
master tech
Site Moderator & Tech
I'm only guessing, That you may have leaking valve seals. And when you start the engine up, it runs poorly for a few mins. Are you using Mopar parts for the sensors and plugs. If not I would.
Old Feb 14, 2022 | 06:54 AM
jrsick's Avatar
jrsick
concur with first response.
Make sure you are running copper plugs, champion 570 are the stock plugs and work best with your engine.
See if you can get a better code reader to tell you which cylinder(s) are misfiring. The plugs from those cylinders will tell you a lot about what's going on inside.
Old Feb 14, 2022 | 07:47 PM
RAM035.7's Avatar
RAM035.7
old post delete
