Overcooling...TIPM??
Old Feb 17, 2022 | 09:46 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Originally Posted by kejobe
So, it IS supposed to run constantly as long as the mode selector is in the defrost position? Even with the temp selector on hot and AC button off?
Yes. Compressor will remove moisture at any temp setting.
Old Feb 17, 2022 | 10:06 AM
kejobe's Avatar
kejobe
I know the compressor cycles as normal, but the fan is supposed to run constant also?
Old Feb 17, 2022 | 11:37 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Condenser fan always runs when the compressor is being used.
Old Feb 17, 2022 | 11:44 AM
kejobe's Avatar
kejobe
Ok. Never noticed it before then.
On another note, removed the cooling fan and clutch. Ran with no fans at all to get new clutch. Still not getting to temp and it's about 48* out right now.
Old Feb 17, 2022 | 04:26 PM
Order a new thermostat. Or order one online.
Old Feb 17, 2022 | 04:43 PM
kejobe's Avatar
kejobe
I warrantied the Duralast. Boiled the new one before putting it in to verify it works. Still running 191*-196* per scanner. Going to try a new rad cap tomorrow since the gasket is cracked on it, even though it doesn't leak.
Old Feb 18, 2022 | 11:27 AM
kejobe's Avatar
kejobe
UPDATE:
Found Advanced Auto has the Carquest Premium thermostat. Same part number as a Stant. Same part??? I don't know.
Anyway, I got it, put it in.
Also put a new rad cap on.
Hooked up scanner to read temp. Got to 212* then dropped. Expected that. After bleeding the system with the scanner still attached, it's running 194*ish.....still. No change. I can get temp to 204* with heat off and holding RPM's at 3500, then it'll drop to 200*-201*. Drop back to idle and temp back to 194*.
I'm at a complete 100% loss on this one.
Old Feb 19, 2022 | 02:59 AM
Prismatic's Avatar
Prismatic
196 is about perfect, what's the problem? I run a 170 but I (see my signature) tow at 4500rpm pretty regularly, so I need the earlier radiator access.
Old Feb 19, 2022 | 06:09 AM
kejobe's Avatar
kejobe
I've had the truck about 2 years and it always ran at 203*. The needle just barely touching the bottom of center mark on gauge. All of a sudden it started running at 195*ish with the needle about 1/2-3/4 of the way to the center mark. This happened overnight. Last Thursday it was fine. Friday morning this is happening.
So far I've done:
3 thermostats, one in now is Carquest Premium (appears to be a Stant) all supposedly 203*
Duralast temp sensor, reads the same as the old one did with both scanner and gauge on truck
Duralast 16lb radiator cap, have a Mopar 17lb on order
Duralast fan clutch, removed and reinstalled old OEM one as it made it sound like a Mack dump truck
After all this it still runs 195*ish. I'm going to put the Mopar cap on when it gets here and call it whatever. I'm done chasing my tail on it.
Old Feb 19, 2022 | 10:08 AM
rtmtrrdr's Avatar
rtmtrrdr
That temp is perfect! I had to put a 180 degree Tstat in mine to run cool And now I run about what your running. If it’s not causing any problems I say send it
