Oil pan replacement
Old Feb 26, 2022 | 04:50 PM
truk's Avatar
truk
Default Oil pan replacement
where is the oil pan replacemement forum?
anyways 2002 ram 1500 has rusty *** oil pan.
i saw a youtube seems to make me think engine does not need to be jacked up. ? no?
anyways first question is what goop to seal the gasket with?
i keep hearing silicone this and silicone that but my impression of silicone is that it dont want to bond to anything ever had any oil on it.
i have used oil base? gasket sealers that seem like they would work way better. something highly tacky never completely hardens maybe?
tips for replacing the pan welcome.
Old Feb 26, 2022 | 07:28 PM
RedRam2002's Avatar
RedRam2002
Is this on a 4wd or 2wd?
Old Feb 26, 2022 | 09:12 PM
truk's Avatar
truk
two wheel drive
Old Feb 27, 2022 | 11:23 AM
Ram05red's Avatar
Ram05red
Hey there I just changed mine and I didn't have to raise the engine. It does take a little finagling to get it out but I did get it out. I was told do not to put any silicon on the pan gasket as it already comes with its own sealing gasket. No leaks on mine. Check out YouTube.
Old Feb 27, 2022 | 10:18 PM
ol' grouch's Avatar
ol' grouch
two wheel drive
I didn't have to raise the engine on my '02 with the 4.7. It was a bit close, but not overly so. I just used a thick silicone rubber gasket with no sealant. Just be sure to clean the oil pick up tube while you have the pan off. Mine was stopped up causing pressure loss. I got to it before it ruined the engine.
Old Feb 28, 2022 | 08:12 AM
ole buck's Avatar
ole buck
two wheel drive
thank God its not a 4x4. I changed mine this weekend and I promise you it would have been easier just to pull the engine
