2008 Dodge 1500 5.7 4x4 front spacer
Old Mar 6, 2022 | 09:57 AM
kennyjr2000's Avatar
kennyjr2000
Default 2008 Dodge 1500 5.7 4x4 front spacer
On a 2008 Dodge Ram 1500 4x4 5.7 I recently placed a 3'' spacer above the front struts to level the truck. Since I have done this I have noticed that when I turn sharp the front tires seem to be having trouble turning. Best way to describe the feeling of this is if the truck was in 4wd and you make a turn on dry pavement. Does anyone have any ideas why this is happening. I noticed that truck sits a little higher than the back now so thinking about going to a 2'' leveling kit to see if this corrects the problem. Im thinking it could be the pitch.
Old Mar 6, 2022 | 10:13 AM
joelle king's Avatar
joelle king
Originally Posted by kennyjr2000
On a 2008 Dodge Ram 1500 4x4 5.7 I recently placed a 3'' spacer above the front struts to level the truck. Since I have done this I have noticed that when I turn sharp the front tires seem to be having trouble turning. Best way to describe the feeling of this is if the truck was in 4wd and you make a turn on dry pavement. 192.168.100.1 192.168.1.1 Does anyone have any ideas why this is happening. I noticed that truck sits a little higher than the back now so thinking about going to a 2'' leveling kit to see if this corrects the problem. Im thinking it could be the pitch.
it could be the pitch yeah you have to take it to a local mechanic to check it out for you, any pics ?
Old Mar 6, 2022 | 10:30 AM
kennyjr2000
No I do not have pictures of what it looks like when tires are turned at this time. I will try and get some and post them.
