Voltmeter pegged when running
Old Apr 11, 2022 | 03:21 PM
neast70's Avatar
neast70
Lightbulb Voltmeter pegged when running
2005 Dodge Ram 2500 5.7L Auto. When turning the key on voltmeter in the cluster goes to about 1/2, then when started and running pegs out at or near maximum value. Voltage is at about 14.6 when running on a separate meter. All other gauges in the cluster read normal readings. No luck finding a solution yet. I'm thinking this may just be bad ground connection, but surprised no other gauges are affected. I have not had any luck yet tracking down a bad ground.
Thanks..
Old Apr 11, 2022 | 07:50 PM
Probably an internal failure in the cluster itself.
Old Apr 14, 2022 | 04:37 PM
neast70's Avatar
neast70
That was the other thing I was thinking, but didn't say it. Has anyone repaired one of these or am I better off looking for another cluster? Or I can just ignore it and use an external meter..
Thanks.
Old Apr 15, 2022 | 09:44 AM
Wouldn't hurt to pull the cluster, and have a look.... might be an easy fix. Might not be.
Old Apr 15, 2022 | 09:55 AM
neast70's Avatar
neast70
I have looked at more possibilities and sadly I think you are right, My external voltmeter reads between 13.5 and 14.8 v, so definitely within a safe range. My main concern is if I "touch" the cluster will it cause another unanticipated problem, especially with the age of the truck and certain parts starting to become brittle. I'm leaning towards just leaving it alone. If another more urgent issue comes up I'll take the dive then. Thanks!
Old Apr 15, 2022 | 10:06 AM
My theory is: If you fix one thing, something else will break. My solution to that is: Fix stuff, until something breaks you don't really care about, and DON'T fix it. End of Problem.
Old Apr 15, 2022 | 01:36 PM
aleekat's Avatar
aleekat
"Any 30 min job is one broken bolt away from All Day"..(Author Unknow)
