Need some help with shocks...
Old May 10, 2022 | 12:47 PM
Bigmex's Avatar
Bigmex
Default Need some help with shocks...
I'm going to be hauling a new travel trailer and I'm not sure which type of shocks to install to beef up the rear end of my 2006 1500 Megacab. I think because the truck is literally Frankenstein's monster (1500 badge on 2500 suspension /axels set on a 3500 frame all this straight from the factory) it should hold it but I don't know. Any ideas? The trailer has a dry hitch weight of 1,210 pounds and a GVWR of 10,460
Old May 10, 2022 | 04:33 PM
From what I am reading, your truck only has a tow rating of a max of 7800 lbs...... If that's correct, you can't legally pull that trailer with your truck..... IS that correct??
Old May 11, 2022 | 07:25 AM
Bigmex's Avatar
Bigmex
After a lot of research in the last two days, I did find that the transmission is the weak link in this equation.
