05 Chrysler 300c injectors on 04 ram 1500 5.7 will they just drop in?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
So I put 05 Chrysler 300c injectors on my 04 ram 1500 5.7 and when I barely touch the gas pedal it will cruise but when I stomp on it, it spudders for a little then it takes off. Would it be the injectors are bad or are they too big? please help I’m about to burn this old girl.
Check part numbers for the two different vehicles.... There are arguments to be made for both options. (same injectors, or not....) If the numbers are the same.... then they should be direct replacements.
there obviously different in size but connection are the same and they sit in fuel rail the same would I have to tune the truck?
