What Upper A Arm should I get for 04 1500 4WD 5.7? Aluminum ? Steel? OEM or after mar
Old Jun 23, 2022 | 10:58 AM
Joe.G's Avatar
Joe.G
Default What Upper A Arm should I get for 04 1500 4WD 5.7? Aluminum ? Steel? OEM or after mar
Boots are starting to rip on my OEM Upper A Arm, I believe they are original, Should I replace with factory? I see prices are all over the place and some are Aluminum and some are steel, Some after markets list a left and right and OEM lists one part number for both sides.
I am thinking OEM but I am open to suggestions. I do not have a lift kit. The Ball joint is still tight but eventually they are going to fail.
Thanks
Old Jun 23, 2022 | 03:03 PM
jrsick's Avatar
jrsick
Is your control arm and bushings in good condition? If so, I'd just replace the ball joint.
Aluminum vs steel control arm is not a major decision, both will work fine. Steel is better if you work your truck hard and drive rough surfaces. Aluminum is lighter and won't rust.
Old Jun 23, 2022 | 03:28 PM
Joe.G's Avatar
Joe.G
Ball joint isn't sold separate for my year, I did replace just the ball joint in the bottom Arms.
Old Jul 3, 2022 | 06:47 PM
RedRam2002's Avatar
RedRam2002
I went with steel on my last one I did a few months back - the aluminum one had a piece of aluminum around the ball joint break and it came apart during driving, not fun. I'll only go with steel now, same price at my parts place and it has a grease nipple as well.
Old Jul 3, 2022 | 09:59 PM
Joe.G's Avatar
Joe.G
I went OEM Replacement.
