3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi,
Can I get the torque specs for the timing chain sprocket, the tensioner plate bolts and the oil pump bolts. For a 2006 5.7L Hemi.
Of course this info is on-line, but I found numbers of 90 lbs and 35 lbs for the cam sprocket bolt, so just want to make sure.
Thanks again.
From the 2004 Factory Service Manual :
(10) Using Special Tool 6958 spanner wrench with adapter pins 8346, torque the camshaft sprocket retaining bolt to 122 N·m (90 ft. lbs.).
Tighten the oil pump and primary timing chain tensioner retaining bolts to 28 N·m (250 in. lbs.) in the sequence shown (Fig. 82).
