3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I blew up the motor in my 2015 dodge 1500 tradesman 4x4 crew cab it had the 345 5.7l v8 eight digit vin T originally with MDS and VVT well I swapped that motor with a 2006 Dodge Durango 345 5.7l v8 i rebuilt had the crank and cam inspected, lapped the valves, honed the cylinders, reringed, and new gaskets top to bottom I didn’t install the MDS solenoids and the motor isn’t VVT when I try to turn it over it sputters you can hear the exhaust for a half second and it shuts itself down. I’ve been told that i cannot flash the pcm and reprogram it to read the cam sensor instead of the VVT solenoid and that even if I pulled the donor trucks wiring harness and pcm it wouldn’t work because of the security system and key fob is this true? Should I sell the rebuilt motor and just buy one 2009-2018?
Yes an 06 engine maybe the “same” 5.7, but in reality it’s not, just like the body style… i.e. 2nd gen, 3rd gen etc, the hemis also have a 1st, 2nd 3rd gen. You need the same gen as your original.
^^^ This. The 09-up Is a totally different engine and your PCM will not recognize the crank signal. There have been some other changes through the years as well like Magnoom mentioned.
