Transmission/torque converter issue?
I used to have a 2004 Ram 1500 with the 4.7 and 5 speed auto. My wife got that in our divorce agreement. I recently bought a 2007 Ram with 5.7 Hemi. It runs great, but when I put it into drive, the transmission starts to whine. Put it in park/neutral, and no whine. I also noticed that, while driving at a steady speed, it seems to find an "in between" spot, if that makes sense. Kind of a drone sound. If I accelerate, it finds the gear I should've been in to begin with. Is this a transmission issue, or torque converter problem? Thanks in advance for any input!
It’s possible it could need just a TC, but if TC is failing how far behind is rest, TC would fail due to fluid level low, dirty/burnt fluid, overheating trans….which is turn would also stress the internals
Sure it's not the MDS kicking in and out? It will sound funny when it turns off 4 cylinders and the rpm usually goes up about 200-300rpm while it is activated. 06-newer Hemi's have the cylinder deactivation system on all 1500's.
