Nothing wrong - coolant system maintenance
Old Aug 5, 2022 | 01:09 PM
10break's Avatar
10break
Default Nothing wrong - coolant system maintenance
Flushed out and re-filled the coolant on my 07 4.7. Also replaced the block to heater core hoses, t-stat, and t-stat housing. 'Ol girl is now running "a needle width" cooler; this is after an hour on I-75 last Saturday.
Old Aug 6, 2022 | 11:12 PM
lxman1's Avatar
lxman1
Site Moderator
That's about where my 08 Hemi has run since new. Should be around 195-200 at the part of the gauge according to my Diablosport Predator when data logging..
Old Aug 7, 2022 | 08:26 AM
10break's Avatar
10break
I did replace with another stock 195 t-stat. I wish I thought to hook my scanner to read the live data but I'll do that next road trip.
Old Aug 7, 2022 | 06:12 PM
95RAM360's Avatar
95RAM360
I have a 195 degree stat and mine runs a hair below midline…always…..you may still have a small air bubble but not enough for it to cause issue
Old Aug 12, 2022 | 05:17 PM
Later2u's Avatar
Later2u
Re-did my cooling system recently. Needle always was just below the centerline. Now, it's right on the centerline.
The difference is probably the new send unit.
