All shift indicators illuminated, no start, HELP
Old Aug 11, 2022 | 09:51 AM
parlusk's Avatar
parlusk
Default All shift indicators illuminated, no start, HELP
I have an 06 4.7 1500 68k, all my shift indicator light are illuminated, It will not start unless i turn the key over before the indicator shows up on the dash, Also, once when putting it into drive it went directly into 4th gear and threw the code p0841. I turned the truck off restarted it and it ran fine. The shift indicator problem happens about 75% of the time, sometimes it works perfectly. Usually once i put it it drive the indicator selects drive and all is good, sometimes going into reverse it will not go into reverse. I have tried all the suggestions that I have found in the innerwebs, cleaning all my grounds, cleaning the 23 connector pin on the trans, I bonded all the grounds of my fenders together and back to the battery with no change. I am not getting any codes other the one that one time. Any suggestions will be greatly appreciated!!!!
Old Aug 11, 2022 | 09:59 AM
Think I would be looking at the transmission range sensor, and associated wiring.
Old Aug 11, 2022 | 11:37 AM
parlusk's Avatar
parlusk
Mine doesn't have the external range sensor, everything internal.
Old Aug 11, 2022 | 11:46 AM
What trans in there?
Old Aug 11, 2022 | 12:23 PM
parlusk's Avatar
parlusk
pretty sure its the 545rfe
Old Aug 11, 2022 | 01:25 PM
Apparently on that trans, the range sensor is part of the solenoid pack...... not necessarily replaceable easily on its own.
