Positive or negative??
Old Oct 16, 2022 | 08:29 PM
Christinjo's Avatar
Christinjo
Default Positive or negative??
Can anyone tell me which wire is positive and which one is negative. They are coming from the back of the cigarette lighter thing. I have a 2003 dodge ram 1500. Thanks
Old Oct 17, 2022 | 06:41 AM
fj5gtx's Avatar
fj5gtx
You should buy a volt-ohm meter, that answers all your questions. I'd have to guess here, but the thick red wire is likely +12vots.
Old Oct 17, 2022 | 06:54 AM
jrsick's Avatar
jrsick
Definitely test with multimeter/DVOM before stripping wires. Disconnect the plug, touch multimeter probes to the clips, and turn key to run. If you get a positive voltage reading then you have correct polarity.
Old Oct 17, 2022 | 08:42 AM
fj5gtx's Avatar
fj5gtx
Cheap work around to not spending $7 on a HarborFreight DMM... cut the wires, ground out a 12v light bulb and test each wire to see which one lights up the lamp.
https://www.harborfreight.com/electr...ter-63759.html
Old Oct 17, 2022 | 05:01 PM
Dirtrang0's Avatar
Dirtrang0
center wire is power outside wire is ground.
Originally Posted by Christinjo;[url=tel:3553336
3553336[/url]]Can anyone tell me which wire is positive and which one is negative. They are coming from the back of the cigarette lighter thing. I have a 2003 dodge ram 1500. Thanks
