07 Ram 1500. Slip Yoke broke from Rear Differential.
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Any insight would be much appreciated. Slip yoke broke away from rear diff. Wheels locking up, vibration, and noise. Can I possibly just replace slip yoke or is my rear diff. Junk? Slip Yoke separated from Rear Differential.. can I just replace slip yoke or is my rear diff junk? Have to fix myself :/
So the slip yoke is not broken? The bolt holding the slip yoke to the pinion gear is broken? Either that or the pinion gear is sheered/broken? And would have to take the whole rear differential apart and replace the pinion gear? Either that or replace with a used rear diff? Hoping to get her on a lift soon and get a better look. Thanks for the insight.
It's just a yoke, there's no slip (or there isn't supposed to be, yours is f@cked). Slip yoke is the one that goes into the trans on the splines, because it is designed to SLIP......
