Hard to get into lo 4x4
Old Jan 2, 2023 | 02:47 PM
HoustonHauler's Avatar
HoustonHauler
Question Hard to get into lo 4x4
05 5.9 3500 Automatic To put in or out of lo 4x4 i have to wriggle the gear change lever around the neutral position. Also 4x4 hi range have to almost stop for it to go in or out
Old Jan 2, 2023 | 04:38 PM
00t444e's Avatar
00t444e
Linkage might need lubricated or have some worn out bushings, you can shift back and forth from 2wd and 4hi at any speed but to shift into 4x4 low you have to be stopped with the transmission in neutral.
