Hey guys hoping for some help. The other day I was driving and had a p0304 code come on. I replaced the plugs thinking that was the culprit but then got a p2311 code so I replaced the ignition coil on cylinder 4 and still same issue. I then swapped plugs and coils with cylinder 2 and the code did not follow. When I switched the plugs I noticed that the ones in 4 still looked brand new like there not getting power. Anybody have a similar issue? Any help would be greatly appreciated! 2 on left from cylinder 4. In socket cylinder 2
Hey thanks for the reply! Can the noid light also be used on the ignition coil or just for testing the injector? Both codes are pointing towards cylinder 4 so hoping everything is good on 2 and the pattern is just due to the motor only being run a few minutes to see if anything cleared the code. Truck starts and runs fine besides a shake at idle
