Main bearings
Old Feb 23, 2023 | 05:04 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by Ram05red
No noise at idle and when it's warm it goes to 0. Been going on for a few years.
Zero means NO oil pressure. If this was truly the case, your engine should be making noise. Replace the oil pressure sensor. Right above the oil filter on a 4.7L.
Old Feb 23, 2023 | 05:49 PM
jrsick's Avatar
jrsick
Testing with mechanical gauge and replacing sensors are both excellent suggestions.
Other possibilities; oil pickup tube is clogged, oil pump is clogged or failing.
I would need to see what the top of the head looks like; is everything clean up top, or, is there sludge?
I'd rec more checks before going rebuild route.
Did you buy truck like this, or have you had it for a while?
Old Feb 23, 2023 | 06:21 PM
Dodgevity's Avatar
Dodgevity
Auto parts store will rent a pressure tester for for free, once you return it.
Old Feb 24, 2023 | 10:07 AM
dodgetruck2's Avatar
dodgetruck2
For what its worth I replaced the sensor on mine with no change in readings.
I don't believe the truck actually has 0 pressure. It drops from the low end of the gauges to 0 to fast and never reads in-between my assumption is its the sensor is more and on off switch then a sensor, anything below 35-40 it just reads zero. I would've long dropped out the bottom end if it was actually going to zero, as would the OP it sounds like
My 06 4.7 I did have oil pressure reading issues also and it did turn out to be the sensor. I forgot about that, I dont remember the exact symptoms, I think I just had no oil pressure all the time on the gauge
Old Feb 24, 2023 | 03:31 PM
Ram05red's Avatar
Ram05red
I've changed the sensor, changed the oil pickup tube, and put a gauge on it and it read 0 at idle when warmed up. I changed the oil a few times.
Old Feb 25, 2023 | 11:11 AM
fj5gtx's Avatar
fj5gtx
Not so easy to swap the oil pump, but I think I might do that before the bearings.
Old Feb 25, 2023 | 03:40 PM
Dodgevity's Avatar
Dodgevity
The oil sump/pick up tube is where I would look to next.
