Main bearings
Old Feb 21, 2023 | 03:36 PM
Ram05red's Avatar
Ram05red
Default Main bearings
Hello, all has anyone ever changed the main bearings without removing the engine? I just heard about this and wanted to know if it was worth the trouble.
Old Feb 21, 2023 | 04:48 PM
Why do you want to change the bearings? What are you driving? 2 or 4 wheel drive?
Old Feb 21, 2023 | 06:37 PM
dodgetruck2's Avatar
dodgetruck2
Description looks like a 4.7.
there is a cross member very close to the oil pan in the 3rd gen chassis, on a Cummins its never to impossible, lifting the motor would be a must.
A 4.7 may provide more possibility. I've had the oil pan off a 360 in chassis of a 2nd gen with ease and doing lower bearings wouldn't be to hard.
I would consider rod bearings as well if you're going to the effort. but also, I would ask your reasonings for such.
Old Feb 22, 2023 | 03:26 PM
Ram05red's Avatar
Ram05red
I have a 2WD. My reasoning is I have that dreaded low oil pressure at idle and it was just a quick fix. Some day I want to rebuild the engine when I have time.
Old Feb 22, 2023 | 03:35 PM
Is it low at idle, or does it drop to zero? If the latter, if you give it a LITTLE bit of gas, does pressure come back up to something more reasonable?
Does it rattle at low RPM??
Old Feb 23, 2023 | 09:46 AM
dodgetruck2
Sounds like your in the same boat I am. Goes really low at first and the light comes on, once fully warm it goes to zero at idle, but no rattle. I had though about doing a bearing set but also am wanting to rebuild a second motor and swap it out someday so I've been leaning more towards a high volume oil pump or switching to 15w-40 oil
Old Feb 23, 2023 | 02:53 PM
fj5gtx's Avatar
fj5gtx
Generally you pull the bearings and you're going to want to have the crank polished or machined... which is a pull the crank operation. I like the idea of getting a cheap used one, rebuild and swap it in over a weekend.
Old Feb 23, 2023 | 03:25 PM
Ram05red's Avatar
Ram05red
Yeah same thing for me. This has been going on for a few years.
Old Feb 23, 2023 | 03:27 PM
Ram05red's Avatar
Ram05red
No noise at idle and when it's warm it goes to 0. Been going on for a few years.
Old Feb 23, 2023 | 03:40 PM
fj5gtx's Avatar
fj5gtx
You could temporarily swap in a mechanical gauge for a second opinion, see if you are really zero at warm, or the factory sensor/gauge is wack. This is a cheap one, with a plastic line... I do not recommend as a replacement.
Amazon Amazon
