Valves ?
Old Mar 6, 2023 | 06:58 PM
DodgeTheFatha's Avatar
DodgeTheFatha
Default Valves ?
Video
so this all started with what I thought was a hydraulic lifter failure , upon inspection, all the rocker arms seem fine and nothing really obviously sticks out to me. Should I keep going and inspect the valves ? I have another video with the initial problems.
Dodge Ram 1500 2003 4.7
Old Mar 6, 2023 | 07:11 PM
DodgeTheFatha
Default Other Video
Other Video
Old Mar 6, 2023 | 08:55 PM
dodgetruck2's Avatar
dodgetruck2
Listening to your video sounds more like a rod bearing to me, Id yank all the plugs and see if you can make the bottom end thunk when turning the crank back n forth
Old Mar 6, 2023 | 09:50 PM
DodgeTheFatha
So how I understood it is to unplug the boots and crank the engine ? Do you think it’s worth pulling the head ?
Old Mar 7, 2023 | 08:40 AM
dodgetruck2
I wouldn't go so far as removing the heads yet, it might come to that depending on what you find but right now I was just suggesting removing the spark plugs to relieve compression pressure when turn the engine, and then using your wrench on the front in the video, or more so probably use a solid breaker bar, not a ratchet and move the engine crank back and forth in rotation a few degrees and see if you feel a "loose" spot and clunk, I'm not positive it'll work just an easier way to start checking for loose rod bearings
Old Mar 7, 2023 | 12:54 PM
jrsick's Avatar
jrsick
Did the noise suddenly start, or has it been getting louder over time?
Anything happen to the truck lately, like an overtemp or fender bender?
Your initial diagnosis is a good a guess as any at this point. You may also want to check for something loose, like a heat shield. Also check around heads for exhaust leak.
Did you just change your oil? How about the filter? Filter is a good place to look for metal bits. If you still have old oil you can get an oil analysis.
I'd try to isolate the sound. A mechanic's stethoscope is handy, but you can use a length of garden hose and hold one end to your ear and the other to various places on the engine.
