Replacing leaf springs on an '05 1500 5.7 4x4
Old Mar 14, 2023 | 07:08 PM
Thatctuy's Avatar
Thatctuy
Default Replacing leaf springs on an '05 1500 5.7 4x4
Well finally figured out why my bed was sitting sooo low. One of the previous owners removed leafs. I sourced a new set of springs + shackles that I'm going to pick up this weekend (still need to get replacement struts b/c I'm assuming they're shot) but had a couple questions about install. Is it going to be easier to remove the tire on 1 side only, support axle, and do one side at a time? Or should I support both sides of the axle, remove both tires, then start working on swapping out the leaf springs? Also, based on the pics (with the lack of leaf springs) I'm assuming it's probably not safe to drive the truck? Any info is greatly appreciated. Thanks.
Old Mar 14, 2023 | 09:48 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Shocks, not struts. Struts are shock/spring combos. You've driven it this long, you'll probably be fine a little while longer. Best way to do this is to put a large floor jack under the differential, then jack it up as high as it needs to go so that a good set of sturdy jackstands (no Harbor Freights) can go under the frame rails. Remove the wheels (otherwise you'll never get enough clearance). Then you can either unbolt the rear from the springs and lower it, then move it out of the way while you replace the leaf springs or you can lower the axle and springs together and replace them on the axle; six one, half dozen of the other.
Old Mar 15, 2023 | 01:56 PM
Thatctuy's Avatar
Thatctuy
Thanks again for the info, greatly appreciated.
