loud humming sound when let off gas!!!
for the past week my trucks been making a loud humming sound when I let off the gas at 40mph from the rear of the truck if i got slower it wont do it.My tires are only 2 months old they are fine.The rear axle fluid is full I cant seem to find whats making this sound anyone?
No lift stock truck stock tires sounds like a tire sound but like I said my truck has stock tires that are 2 months old seems to be coming from the rear axle the sound and today when i shifted from park to drive i get a loud clunk not sure what thats all about makes the loud clunk going ito reverse also so now its making 2 sounds for some reason.
That sounds like a driveline noise. Since it is occurring on deceleration it's likely you need to adjust pinion nut preload.
Other possibilities are wheel bearing(s), front pinion bearing, or u-joint.
Did the noise start recently, or have you noticed it for a while? Did you have an event where differential received a lot of torque suddenly, with rear end hooking up after spinning on an unprepared surface?
Let us know if you want info on adjusting the pinion nut. Not a difficult task, but there are a lot of steps and a few tools required.
