Throttle position sensor
Old Jun 3, 2023 | 10:34 AM
okie555555's Avatar
okie555555
Default Throttle position sensor
Hi all. Figured I would update 3rd gen tps reset. The 15/30sec, did not solve my issue after replacement. What I did, was clear the code. non running. Then turn key to on position, slowly press acclerator down, hold for 1 min. release. turn off. then repeat. it learned the new tps after that.
Old Jun 6, 2023 | 06:48 PM
lxman1's Avatar
lxman1
Site Moderator
Supposedly, you can reset the older one the same way. It kind of re-calibrates that way. Thanks for the info.
