Hemi Swap
Old Oct 18, 2023 | 10:13 PM
Clatech's Avatar
Clatech
Default Hemi Swap
Hello, new here so bare with me on this one. Did a hemi swap with a 2005 1500 5.7, 545rfe trans to my classic truck. Used the stock wiring harness and ECM. Motor runs awesome but the trans is stuck in limp mode. The ECM is not seeing the trans for some reason. The sensors such as temp and pressure show up on the scanner but have no values. I can disconnect them and do not get any fail codes. I tried a replacement ECM and same problem. Anybody have any ideas to try on this.
Thanks
Old Oct 19, 2023 | 06:51 AM
Are the sensors getting their power feed?
Old Oct 19, 2023 | 05:28 PM
Clatech's Avatar
Clatech
Yes, 5.3 volts.
Old Oct 19, 2023 | 06:21 PM
Clatech's Avatar
Clatech
Does the ECM need to see the wheel speed sensors?
Old Oct 22, 2023 | 11:10 PM
Harsens's Avatar
Harsens
A friend who works in the plant told me they are notorious for changing the wiring. I found this to be true when I swapped worn cloth for a nice set of leather seats. The wiring was different so even when I pugged the original to the truck wiring harness the wires connected to the seats were different. The only thing that was the same was the seat belt light. Just food for thought.
