3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 2004 Ram 1500 5.7 that I just put a used rear end in, same year. It is a 3.92 and when I have it on jack stands I turn wheel forward and the opposite wheel doesn't turn but the driveshaft turns. When I turn wheel backwards opposite wheel turns in the opposite direction and driveshaft barely moves. Is this normal? I started feeling a bumping in the rear end while pulling away straight from a red light so I've had it parked. I have put less then 30 miles on the truck after the new rear end and when I was blocks from home is when I started feeling something. I haven't opened the cover yet, I wanted to ask if the wheels were acting correctly before proceeding.
Yeah, that's normal behavior for an open rear end. The 'bump' though, is not..... need to figger out what that's all about.
My original rear end rusted on one end from being a Michigan truck, the parking brake flipped sideways and the C clip released. I see you're in Michigan too.
